In my project I have a date field called "planned end date". I want to filter issues which are not completed and have missed the planned end date by 5 days or more . How to get this list of issues using JQL please
resolution is empty and "planned end date" <= -5d
Hey Sharmila,
the correct JQL shoud be
project=XXX and "planned end date"<=-5d and statuscategory not in(Done) order by "planned end date" ASC
If you need to have it based on hours, you could also exchange -5d with -120h or other values.
You can change "order by" as you wish, this sorting would show the most missed days since milestone first in the list.
Best regards,
Benjamin
@Sharmila Hiranandani if this helped you solve your issue, please consider clicking on the 'Accept Answer' button to help other people looking for a similar answer
Basic arithmetic with dates is described in automation/docs/jira-smart-values-date-and-time/
kind regards,
Dick
Thanks. But I need to do this in JIRA issue filter . And the info mentioned in the document you shared does not work in JIRA issue filter / JQL. I am creating a status report in Confluence and I want to show the count of issues which have missed the milestone date by more than 5 days.
Hi @Sharmila Hiranandani
The {{smart values}} give you an opportunity to construct the result into an output string
Also {{now.diff(issue.created).weeks}} is a nice example where the output is the number of weeks ago that an issue is created. That's only a hair apart from your request.
Combined with conditional logic described by Atlassian, it provides you with a means to create the content of the status report you desire.
Dick
