You cannot do it in an inactive workflow. You have to activate this workflow, then you will see the approvals. It should be inside the JSM project.
This is the right answer, thank you!
I activated the workflow and it works
As I can see you are using Jira Software, and approval is only available for Jira Service Management workflows.
I hope this helps
