I have an internal workflow I am building out whereby external customers can submit a ticket through Jira Service Management and have it replicated over to Jira Product Discovery as an idea. One issue I am having is that I capture some information in a custom field on the JSM side that I am unable to copy over to a custom field by the same name within Jira Product Discovery.
I know that they are technically different fields, but I am not sure how to even reference the field on the Jira Product Discovery side, or if that is even possible. Even when I look at the automation options inside of Jira Product Discovery, the issue fields that are accessible seem to be globally set ones.
Any pointers?
Hi @Ylan Muller
To learn if a field is supported by automation rules, please use the how-to article linked below. Essentially you find an example issue (or idea for JPD), call the REST API with a browser, and search for the field. If it is not present, it is not supported by rules. This technique also helps to confirm the correct smart value syntax for a field, as smart values are name, spacing, and case-sensitive.
https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Once you find your field, you may need to use JSON to edit it. Please look here for information on that technique:
https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/
This is excellent, thank you for linking these resources! Worked exactly how I needed it to.
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
