Moving Jira instance to DMZ
lance_lyons
July 20, 2012
We have half a dozen developers that need access to our jira instance. Currently it sits internally and every thing is configured perfectly.
Is our only option moving Jira to the DMZ (external side of firewall)?
Has anybody done this before?
Can I setup an Apache instance externally and do a reverse proxy to the internal Jira site?
Any suggestions?
twong_atlassian
December 7, 2012
Hi Lance,
JIRA works fine with a reverse proxy.
Here's a doc for how to do that:
https://confluence.atlassian.com/display/JIRA/Configuring+Apache+Reverse+Proxy+Using+the+AJP+Protocol
Tim
Plexus ALM Support December 7, 2012
We have our Atlassian tools hosted internally and are planning to give access to all via Citrix.
Norman Abramovitz
August 28, 2012
There are remote control applications you can use to access your office computers if your network administrators allow outside secure access. Each has its pros and cons in terms of perfomance, features and usability.
Here is one article pointing you at some of the more popular products out there.
http://compnetworking.about.com/od/homenetworking/tp/remoteaccesssw.htm
Harry Chan
August 28, 2012
Hi, whatever change that happens, ensure that the base URL and the URL to be accessed will be the same to not cause any issues.
Your other options could be VPN / Citrix access to your internal networks.
