Moving a story to another epic in Portfolio doesn't update JIRA Agile?
Bernard O'Flynn
If I move a story to another epic in Portfolio Cloud, the epic in Agile isn't updated?
How do I get it to sync?
MatthiasS November 19, 2015
Same here. Has anyone tried removing the old epic link manually?
Lennon Cork
September 25, 2015
Same here, I've reverted to updating the epic link manually and re-importing into Portfolio. Will let you know if it works out. Did you come up with a solution? Is there a bug or ticket logged for this?
Alexey Blinov
May 28, 2015
Same question here. And yes - we did "Plan -> Apply updates to project/s". Issue doesn't moves from one epic to the other.
Ivar
March 24, 2015
Let's build A Rovo Agent 🤖
Save your spot
