How can I move a card between boards within the same project?
You don’t move cards between boards. Boards are simply displaying issues based upon the filters that define them. So to have an issue displayed on another board look at the boards filter and adjust the issue to align. Hope this makes sense.
That doesn't help with reporting, burn down or sprint health.
It is relevant because if a board is addressing multiple initiatives and you only want to see reporting on a single one, filtering doesn't work. That is probably why they want to move cards to its own board.
I'm sorry but I still am not following. What is displayed on a board is completely driven by filters. If you wish to change what you see on the cord change the filter. This could be the general board filter or quick filters, etc.
this original post was talking about attempting to use the move command to move it issue between boards. The move command is not used for that. It is only used to move it to a different issue type that has a different workflow or to a different project. If you have multiple boards associated with your project, for whatever reason, and you wish to 'move' an issue from board A to board B then you need to understand the different filters so that you can modify the issue such that it disappears from board A and appears on board B.
Not always. Some boards need not filter on anything and show only the cards assigned to that sprint. Additional filters may apply to exclude or include specific cards tagged with that filter value. BUT if someone is using a combined board and trying to get specific metrics based on the filtered value, it doesn't allow one to see burn down, sprint health based on that filter because those reports are at the board level.
Basically you will have to create a new project with it's own board. You sound like us, we have multiple items on the board between multiple teams and the team operates differently. The Scrum Master can't get to her true burn down or sprint health because everyone's cards are on the board and one can not filter at the burn down or sprint health level just at the project level so it's limiting.
@Diatta Harris , every board has an underlying filter regardless of whether you can access/visualize or not. Sprints are indeed based upon a filter. Well actually two. The primary filter illustrates what shows up in the backlog. The second 'sub-filter' is created when you create a sprint and drag issues from the backlog and into the sprint. Then when start the sprint those issue appear on the active sprint board.
example....
I understand things are filtered. Our issue is at the project level our burn down rate reflects all tickets affiliated with that board. Are you saying there is a way to recreate the board and use special filter to include the tickets they want to see? If so, that doesn't sound like we will only see burndown and sprint health with that data filter and the project level.
No. I was just commenting on the fact that all boards are based on filters.
if you want to isolate Burndown, etc to a subset of a board/sprint you have two(?) options. Either you create different boards and run different sprints or you 'label' the issues to compartmentalize them then export the results and analyze using something like excel. There may also be an addon option to consider.
Re: Creating a new board, it will create it's own burndown even if under the same project?
Yes. You can run parallel sprints too. The burndown is specific to a board not a project.
