Hi @Ahmed Maher ,
You cannot assign one issue to multiple assignees but you could manage them using Team field or a custom field User Picker (multiple users) or Group Picker (single group or multiple groups).
There is a very similar question here:
Hi @Ahmed Maher ,
Jira doesn't support multiple assignee.
you can achieve this by various other options like,
Refer below link for some other options provided by @Nic Brough -Adaptavist-
https://community.atlassian.com/t5/Jira-questions/add-multiple-assignees/qaq-p/2041518
Hi @Ahmed Maher
This is not possible for the assignee field. One option is to create a multi user picker custom field instead.
Regards
