Multiple Boards (1 Scrum, 1 Kanban) in 1 Project
Daniel Conway August 17, 2021
How do I create multiple boards? When I try to my project isn't in the dropdown...
Jack Brickey
I suspect that your project is not a software project. You might find this article that I created a while back useful - Multiple-boards-in-Business-and-Team-Managed-Projects-You-bet-you-can!
It's a software project
Jack Brickey
The article will apply to creating another board in a TMP. Have you attempted as described in the article?
Daniel Conway August 18, 2021
Got it!
Just took a look... I'm unclear on the purpose of the filter in the article. Can you clarify? And what the parameters of the filter should be...
Jack Brickey
The filter is what will be used to create the board. For example if you simply want a kanban board that references all issues in your TMP project then the filter would look like this
project = myTMPproject
replace myTMPproject with your project’s keyi
Like Del Jensen likes this
Daniel Conway August 20, 2021
This worked! Thanks very much. Now just confirming that my team can see it.
Also, quick update, it's now "+Add shortcut" instead of "+Add Item" in #8 in the article.
Thanks again!!
Trudy Claspill
Are you using a Company Managed or Team Managed project? It will say at the bottom of the navigation pane on the left?
Are you using a Work Management/Business project, Software project, or Service Management project? That will be specified at the top of the navigation pane on the left, just below the project name.
It's a team-managed software product!
Trudy Claspill
Team Managed projects don't support multiple boards, technically. There is a change request to add that feature.
https://jira.atlassian.com/browse/JSWCLOUD-17371
When you create a Team Managed project one board is created for you automatically. The way boards function and the customization features available there are different than the way boards function and customize for Company Managed projects.
Have you worked with Company Managed projects and boards created for those?
You can create additional boards based on a Saved Filter that references the issues in the Team Managed project, but the board will not function the same way as the board that was created with the project.
I have not worked with Company Managed projects and boards.
How do I do the Saved Filter you describe? Thank you!!
Trudy Claspill
This page talks about how to save a filter and has links to other articles on creating filters.
https://support.atlassian.com/jira-work-management/docs/save-your-search-as-a-filter/
This article talks about how to create agile boards as it would be done for a Company Managed project.
https://support.atlassian.com/jira-software-cloud/docs/create-a-board/
Please be sure to review the limitations that are noted in the Comments on the article provided by @Jack Brickey .
Thanks for your help here Trudy!
