Sign up Log in
Multiple Boards in Next Gen Projects
SR June 3, 2020
Can you create multiple Jira Boards in Next Gen Projects?
I notice that all issue types have the status of the columns on the Jira board but my team would like to be able to have Stories have a different status than Bugs for example.  I am wondering if the answer to do this is to have multiple boards
Jack Brickey
June 3, 2020
Hi SR, you can’t create boards “in” a NG project. However, you can certainly create a classic board (scrum or Kanban) using a filter that is associated with a NG project. Just go to view all boards and create a board and associate to a saved filter or simply the project.
