Our team uses the Multiple Checklists for JIRA plugin, to keep track of both the Definition of Ready (DoR) and Definition of Done (DoD) of our Stories. We add the DoR on each Story automatically when it is created and the DoD when the Story is set to status In Progress.
Adding "Multiple Checklists for JIRA" to our card layout means we now see a total sum of DoR and DoD on our cards: If both are 10 items long, the cards now show "10/20" (10 out of 20 checked).
Is it possible to only show the DoR checklist on the 'backlog' card layout and only show the DoD checklist on the 'active sprints' card layout?
Welcome to the community. I assume you use a checklist app like, Issue Checklist Pro. You can show the progress of the checklist, but it is just one list. You might have divided it into several sections, from a technical point view it is one list. So you can't display the progress of DoD and DoR separately.
But you might contact the vendor of the app. It is a nice use case, so perhaps they can assist your, by adding the feature.
Rudy
Hi @Rudy Holtkamp , thanks for getting back to me! Yes, it is indeed a marketplace app. I see there is a separate folder for those questions, I will ask there!
