My updates on a field are not appearing in a lookup
Karamba Marenah September 27, 2019
I have updated a field in Jira "Create an issue" and it is visible but not showing in the lookup in the field.
The old values are the ones that come up.
John Funk
September 27, 2019
Hi Karamba,
What type of field is it? Single select? Multi select? User picker? Text?
Lookup values are typically controlled under the Configuration for a Custom Field.
Karamba Marenah September 30, 2019
The field is a cutomer one with mutiple select. I kan see it but the old one comes up under lookup. It seems the new fields are not activated.
