My velocity report is empty
David Ansari May 22, 2023
I have multiple sprints sets in my project and some of the sprints have been completed. When i try to pull the velocity report, it comes empty. Please assist.
thanks
Nic Brough -Adaptavist-
May 22, 2023
Jira does not display the first couple of sprints (which I find annoying), but keep going and you'll get them/
The important thing about the sprints is estimates and done.  Make sure your issues have a value for the field that you have chosen as the estimate, and then make sure your people understand that the last column on the board is the only one that matters for "done".
Dave Liao
@David Ansari - can you share a screenshot here, please?
Like • Dave Liao likes this
Dave Liao
May 22, 2023 edited
@David Ansari - can you confirm if any of the sprints contain pointed stories? That is, do the issues in those sprints have values in the Story Points field?
If not, what you're seeing is correct.
If so, that's definitely not good!
@Dave Liao Yes, the stories have value point.
Dave Liao
@David Ansari - can you confirm what the JQL is for your board's filter?
(Feel free to anonymize the names of projects, or any sensitive info.)
Did you mean this: project = GPJ1 ORDER BY cf[10007] ASC
Or where am i looking for it?
Dave Liao
@David Ansari - that looks correct!
(On your board, you'd click "..." then "Board settings" then "General" (if you're not on that section), then look at "Filter query")
Thats what it shows me. Just not sure why the velocity is blank. Any idea how i can go about fixing this?
