×I was navigating in the Issues section, added a custom filter, came back to find the Backlog showing 0 issues present, with no pre-set filter ON. Also no issues present in Active Sprints. This is a serious bug! Tried from the Jira app as well, the same scenario over there!
My first guess is that this is not pointing to a bug. Rather I suspect you have edited the board filter impacting the issues shown in the board. When you say you added a custom filter could you explain a bit more about what you did exactly? Also is this a CMP if so could you please share what your board filter looks like?
The filter was to show the issues of all sprints. And it was created in the Issue explorer. I checked with the board filters, no special filter active yet, the problem persists.
Ok, I resolved the problem. By mistake, the Board filter got edited. Thanks Jack, you reduced my pulse rate!
