Need JQL to filter all tickets of past 4 months created between night 10 PM to 6 AM IST
binay_yadav March 16, 2021
Use case:
I am trying to create a chart to get all the tickets created between night 10 PM to 6 AM IST, the chart should have months in X axis and count in Y axis. Data needed for past 4 months.
I tried using the below mentioned JQl but it only returns me ticket for one day and the same is required for atleast 4 months.
project = L3I AND created > startOfDay("-2h") and created < startOfDay("+6h")
Trudy Claspill
Hello @binay_yadav
Welcome to the community
I don't believe there is a JQL that can be used out of the box for JIRA Cloud to get you this information.
You could probably find an app to add to your JIRA instance that would help with this. Alternately you could investigate adding a custom field to track the hour of the day when an issue was created, and seeing if you can set that field for each issue using the Automation feature to evaluate the Created date/timestamp.
binay_yadav March 18, 2021
Hi @Trudy Claspill  Thanks a lot for your help, can you please suggest any add on for the use case to work or else I'll try the automation method 🙂
Trudy Claspill
Sorry, no, I cannot. It is not a use case in my company so I haven't had to find an actual solution. If you do an internet search for "jira report on tickets created during time of day" or something like that then I'm sure you'll find other community posts and maybe even links to apps in the marketplace.
Like • binay_yadav likes this
binay_yadav March 21, 2021
@Trudy Claspill  Thanks a lot for helping out :)
