×Can someone give me a template of the Excel that can be used for importing
Hello @Jeson Duthie
Welcome to the Atlassian Community.
You can extract the ideal CSV template directly from your own site. These would be the steps:
The file exported will have all the fields you currently have for your issues described in the first row, so you can simply delete the values from the next rows and use the header as a template. The only required fields to make the import works are Summary, Project Key, and Project Name, so it's okay If you want to keep some fields empty.
For more details about CSV imports, you can check the documentation below:
Let us know if you have any questions.
