Need more attributes for subtasks
Diane v July 29, 2020 edited
Hi all,
We're currently trialling this app (xporter), and it looks really promising for us in order to be able to export Stories and Requirements to a Word template. We have Stories sitting at the Issue level, and we're able to export what we need at this level, however, we have Requirements sitting at the subtask level, and not all the attributes we wish to export appear to be available.
In reference to: https://confluence.xpand-it.com/display/public/XPORTERCLOUD/Iterations#Iterations-IteratingIssueSubtasks
We also need:
${ Subtasks[n].IssueType}
${ Subtasks[n].Description}
Is there some way of also exporting these attributes?
Or can someone suggest an alternate approach that would yield the same results?
Thank you,
Diane.
Diane v August 4, 2020
For those it may help in the future - I heard back from support via a ticket I logged:
Yes, those mappings are available, we tested from our side and it's working, can you confirm that?
#{for j=subtasks}
 ${Subtasks[j].Key}
${Subtasks[j].Description}
${Subtasks[j].IssueType}
#{end}
Diane.
