Need to make a field required upon close of issue.
Amy Schindel
I need to make the documentation field required when an issue is closed.  I know this is done by adding a validator. However, in my workflow, any status can transition to closed.  Do I need to create a transition from EVERY status to closed and add the validation on each of them for it to be required?  Or am I missing another step somewhere?
Karan Sachdev
January 13, 2025
Hey Amy,
You can click on the "ALL" global transition available for the Closed status and add the required validator.
Karan
Amy Schindel
Ohhhh!  Thank you! I didn't even think to click that!  I appreciate the quick reply!
Karan Sachdev
January 13, 2025
You're welcome, Amy!
Could you please accept the answer so it would help other users with a similar query?
