Need to move data from Wrike to Jira cloud instance.
Samuel Prathipaty
We want to move data from Wrike to Jira cloud instance. Is there is a plugin that can be used for this purpose? Just to move the data. No integration needed. The reason for that ask is there is a lot of data that does not come along in this excel export.
Sam Bartolome July 17, 2024
Hi @Samuel Prathipaty
It may be solved already but this integration may help to sync issues between platforms, https://marketplace.atlassian.com/apps/1223936/getint-jira-wrike-integration-sync?hosting=datacenter&tab=overview
Probably the configuration should be done in Jira first and the sync issues instead of export/import
Jack Brickey
I am not familiar with any plug-in solution. Just use CSV import. Tedious but it works.
