Newly created task does not pop up in Board
Fabienne Bühler August 18, 2021
If I create a task INSIDE the JIRA Canban Board, meaning on the bottom in each column, the task appears in the Board. But if I use the main "Create" Button in the upper menu of the web page, the task simply won't end up in the Board. What am I missing here?
Jack Brickey
What displays on your kanban board is driven by the underlying filter. I suspect that when you create an issue outside of your kanban board there is some parameter that falls outside of your filter. For example the status of a newly created issue might be to do and maybe your kanban board as the to do items going to the backlog. for me to diagnose the precise calls of your issue I need to understand more details. Can you provide the following:
  • Your boards filter - board settings > general
  • the status of newly created issues
  • backlog - is it in use? If so what status is mapped to backlog
Fabienne Bühler August 18, 2021 edited
@Jack Brickey
  • All I can see regarding board settings is this:
  • The newly created issues are in the status Approval Pending
  • The backlog is in use but I don't know which status is mapped to it.
Del Jensen
August 18, 2021
@Jack Brickey good point, I forgot about the board filter.  Thank you!!
Jack Brickey
Ok so you are using TMP not CMP so scratch the whole board filter bit.
are the issues created via the CREATE button landing in the backlog?
@Jack Brickey The issues created via the CREATE button end up in the backlog. But I do not understand your first point. What do I need to change?
Jack Brickey
in my first reply I wrongly assumed that you were using a CMP project but in fact you have a TMP project. you don't need to do anything here.
Things appear to be working as expected. If you create an issue in the board that creates it in that status. the create does so in the backlog.
Like Bill Sheboy likes this
So if I create the issue via the CREATE button there is no way it will end up in the Board? Only if I create it in one of the columns in the Board?
Jack Brickey
you could disable Backlog - project settings > features
Like 2 people like this
Thank you very much @Jack Brickey,  that solves our problem.
No, even after a refresh it does not pop up. I can only find the issues in the Roadmap and Issues List, but not in the Board.
Del Jensen
August 18, 2021
@Fabienne Bühler are you looking for an automatic refresh?  If so, I don't believe that happens.  I need to refresh the page and then the issue will show up.
