NextGen - Filters or status drop down
Uma Sanjeevi
Hi
Is it possible to enable filter option in the nextgen version ? For example - I only want to see all cards in the column “in progress” at times when I am planning ...
i can’t be adding labels and filter by labels .. adding label and removing labels is an effort
is this possible ?
thanks
Uma
Walter Buggenhout
Hi @Uma Sanjeevi,
No, not as far as I can see. What is in progress is in the progress column. Filtering and sorting can be done on issue type, assignee or keyword, Epic or Version if you use those.
In backlog view you can enable the epics or versions panels, but that's it I'm afraid.
Uma Sanjeevi
yeah - used to have this available in the prv version .. just helps sometimes to filter the cards all in a give status ... rather than scrolling up and down..
I do have program level work in a board and helps to get such reporting view.
