I have a need to automatically clone an Epic and task/subtask under it. Because we can't clone epic I wrote an automation rule.
so I created Manually trigger rule Where it will create an epic/task and subtask.
I was able to link Task to EPIC using the following JSON
"fields": {
"parent": {"key": "{{issue.key}}"}
but no matter what I do I can't link subtask to TASK. Help Please
Error I get
Error creating issueGiven parent issue does not belong to appropriate hierarchy (parentId)
Hi @Neetu Verma
Cloning spanning 2 levels seems easy (epic to task, or task to sub-tasks). Cloning spanning 3 levels (epic to task to sub-tasks) isn't possible yet with one rule. There are suggestions to make the cloning of sub-tasks easier:
https://codebarrel.atlassian.net/browse/AUT-335
https://codebarrel.atlassian.net/browse/AUT-162
You may be able to do it with multiple rules:
Please see this post to get ideas how the linking of sub-tasks might be done:
Best regards,
