Not able to add tab in the Issue Card layout
José Carlos De Oliveira Escalona
I am trying to add a tab (as the one on the screenshot) to the Issue Card screen layout
In order to configure the screen, I need to access the Issue Configuration inside project settings.
It turns out, the Issue settings is not available when the Project, type Software, uses Kanban or Scrum Templates
This is only available using Bug Tracking Template
There is not information whatsoever, about not being able to configure Card's screen depending on the project template
Anyway to overcome this?
I want to add tabs to some projects I already got using Scrum or Kanban templates
Screenshot 2023-01-07 at 20.47.15.png Screenshot 2023-01-07 at 20.47.33.png Screenshot 2023-01-07 at 20.50.45.png
Ste Wright
Hi @José Carlos De Oliveira Escalona
This isn't an issue between Bug, Scrum, or Kanban templates (which just provide different configurations) - you have two different Project types here, Team-managed (top screenshot), and Company-managed (bottom screenshot).
Team-managed Projects cannot have tabs at this time as far as I know - you could create a feature request for it though here if you would like to: https://jira.atlassian.com/secure/Dashboard.jspa
Company-managed Projects can though - you can add a tab via the Screen settings. You'll need to be a Jira Admin to modify these settings - then:
  1. Go to Settings (cog icon in top-right corner) > Issues
  2. Select Screens from the left-hand menu
  3. Locate the Screen relevant to your Project
  4. Add a Tab using the hyperlink on this page
For more information on what you can do to customise a screen, see this help page for Team-managed Projects, and this help page for Company-managed
Let us know if you need any further help!
Ste
Hi Stephen, thank you very much for your reply
It will be a lot more helpful is this information is straight in the help section when describing how to add tabs! ...just saying
Can you swap the project type without creating a new project a moving all things around?
Regards
Jose
Ste Wright
January 9, 2023 edited
Unfortunately you can't at this point when moving between Company-managed and Team-managed - you have to create a new Project, then move the Issues across.
There's a good, detailed guide on how to do this - see: https://support.atlassian.com/jira-software-cloud/docs/migrate-between-team-managed-and-company-managed-projects/
Ste
FREE
Help us plant more trees
