Not able to import test cases to Zephyr via excel
archana_veerathappa
November 28, 2023 edited
I get the below error while i try to import the test cases written in excel. Assignee field is not working in-spite of trying all names and format.
this is when i give nothing in the assignee column:
Master Row : 1, Sheet Name : Sheet1, Error Message : Error while creating issue : {"assignee":"The default assignee does NOT have ASSIGNABLE permission OR Unassigned issues are turned off."}
Master Row : 4, Sheet Name : Sheet1, Error Message : Error while creating issue : {"assignee":"The default assignee does NOT have ASSIGNABLE permission OR Unassigned issues are turned off."}
When i give a valid name firstname.lastname or firstname.lastname@gmail.com or firstname_lastname:
Master Row : 1, Sheet Name : Sheet1, Error Message : Error while creating issue : {"assignee":"Specify a valid value for assignee"}
Master Row : 4, Sheet Name : Sheet1, Error Message : Error while creating issue : {"assignee":"Specify a valid value for assignee"}
CHINNAMUTHEVISAI.SATYANARAYANASHARMA
Please check the permission scheme for that project and see the assignee have permission or not.
archana_veerathappa
November 28, 2023
Hi @CHINNAMUTHEVISAI.SATYANARAYANASHARMA , I have been given 'Admin, PM, QA, SQA' permissions. But still it is not working.
