Not all issues are shown on Kanban board if I set grouping in swimlanes to Epics
Bond October 9, 2019
Custom query is the following:
project = LUNA AND issuetype != Epic AND updated >= -5d ORDER BY updated DESC
If I select swimlanes = Epics, then I do not longer see on the board the issues with no Epic assigned.
I did already tried to remove the "..AND issuetype != Epic" from JQL, but then board shows me just issues with one or two Epics, and completely ignores others (while if I just the query itself - > then I see all the issues I need).
Jack Nolddor _Sweet Bananas_
Hi Bond,
While grouping issues using Epics as swimlanes, issues not having any Epic related will be shown in a new swimlane at the botton of the Kanban board called 'Issues without epics'.
Does not your case?
Regards
Bond October 17, 2019
Hello Jack, let me explain the problem in more detail. See these 2 screenshots: 1st shows the board without any grouping - OK, you can see 3 issues there and 2 of them have different epics assigned. Now, if I switch to group by epics - see 2nd screenshot, you (very surprisingly) just see issues without assigned epics only.
