Not returning fix version in API call
Mark Davies
January 28, 2022
Using the following URL: https://ctl.atlassian.net/rest/api/3/search?jql=filter=66847
to return the results (which it does correctly), the filter itself is:
issuetype in ("Portfolio Epic", Capability, "Epic (Feature)", Story) AND issueKey in portfolioChildIssuesOf(ABC-123) AND status not in (Done) ORDER BY key
Yet, when I look at the result in JSON - it shows a "list" but all fix versions are empty. How can I resolve that?
fields
fixVersions[]
14
fields
fixVersions
15
fields
fixVersions
16
fields
fixVersions
17
fields
fixVersions
18
fields
January 28, 2022
Hi @Mark Davies
I just tried this for my own filter and it worked for me.  Some things to check are:
  • Run the JQL manually in advanced search and confirm it works, and confirm the returned issues actually have fixVersion values
  • Run that same REST API call in a browser to confirm it works, and look for the fixVersions.  If it works, it may be how you are consuming the response.
Get Certified! ✍️
