Not seeing a checkbox default to Checked in a screen
Phil Bustin
Attempting to follow the instructions below, I came up with the following configuration (seems like duplication to me), and when I select a transition that contains the field, the value Checked is not checked.
Instructions:
Field configurations:
Masudur Rahman
Looks like the checkbox field has to have at least one issue associated with it and then only checked works. So if you are stuck like me, then manually check the options and next time onward default checked option will be checked.
Phil Bustin
April 12, 2023
This is an old post, and I believe my checkbox is working now.  Also, at the time, I didn't understand how Jira checkboxes work, and I've changed the options; instead of indicating what the checkbox is used for in the checkbox name and using options Checked and Unchecked, I generalized the name and added 7 options with direct names.
Dave Mathijs
Hi @Phil Bustin , why are you using 2 different contexts?
The first one is global (all issue types, all projects)
The second one is restricted to the mentioned projects for all issue types
Default value and options are the same.
Do you have screenshot of your transition screen?
When you are viewing an issue, is the field displayed on your screen with value Checked?
What type is your field?
Phil Bustin
Hi @Phil Bustin , why are you using 2 different contexts?  Because I couldn't understand the instructions.
The second one is restricted to the mentioned projects for all issue types  I'll delete it.
Default value and options are the same.  What do you mean?
Do you have screenshot of your transition screen?  Below
When you are viewing an issue, is the field displayed on your screen with value Checked?  No.
What type is your field?  Checkbox
Phil Bustin
As a better solution, or possibly a workaround, I set an automation for the previous transition to set the default value to Checked.  Now, when the next transition is selected, the default value = Checked.
Phil Bustin
I will likely open a new question here, but in the transition in which the default checkbox value is Checked, when I click Unchecked, Checked remains checked.  That is not the behavior of a checkbox.
FREE
Help us plant more trees
