Not seeing a "you've created" pop-up after automation runs
Michelle Rose
I built an automation that manually can clone an epic and all its stories in a new epic. When the automation runs, I don't get a pop-up (like in the image) so I have to go to the audit log to find the link to the new epic. How can I enable this pop-up for the automation?
2 accepted
Greg Brown
Hi, @Michelle Rose
One thing that might help is to add another action to the end of the automation -- the Comment on issue action.  This way after you run the action, a link to the newly cloned issue(s) will show up in the comments of the issue you are working in.  I tried it out with something like this:
This manual clone automation created the following issues:
{{createdIssues}}
I hope this helps.
Thanks, Greg
Michelle Rose
Thank you @Greg Brown!
Like Greg Brown likes this
Trudy Claspill
July 12, 2023
Clever idea, @Greg Brown !
Greg Brown
Thanks, @Trudy Claspill!
Trudy Claspill
July 12, 2023
Hello @Michelle Rose
You can't enable that pop-up for issues that are created by Automation Rules.
Automation Rules may run without any user interaction, so they will not surface any user interaction elements like that pop-up.
The Manual trigger Automation is a one-off function. While it has recently been updated to support surfacing input prompts, it still is not capable of surfacing the "created issue" pop-up.
You might want to contact Atlassian Support directly to find out if there is a change request for that.
Michelle Rose
Thank you @Trudy Claspill
Organization
February 7, 2025
1 2
