When transitioned from Open to Inprogress, Users "should NOT" be able to
1) should NOT edit custom fields
2)should NOT issue links in the screen
3) should NOT edit comment
4) should NOT attachments
You can set the workflow properties on the Inprogress status to block all those actions (except "custom fields" - the edit permission covers all fields, not just custom fields)
See https://support.atlassian.com/jira-cloud-administration/docs/use-workflow-properties/
Ah, sorry, you can't restrict the issue links like this, there is no "link issue" permission to do it.
Ok, then what is the best way to achieve, script runner ? if so how ?
No, because there's no permission to work with.
@Nic Brough -Adaptavist- Thankyou for your prompt response.
I have tried as you have mentioned and got succeeded to restrict editing while the issue is in "In Progress" status.
But i can able to edit the issue link...
How to restrict that too ?
