Apologies if this isn't the correct place for this inquiry.
The documentation at: (https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-webhooks/#api-rest-api-3-webhook-delete) seems to imply that Oauth 2 implementations should be able to delete webhooks given they have the scope: `delete:webhook:jira`.
But when calling that endpoint I get back "OAuth 2.0 is not enabled for method: DELETE /rest/api/3/webhook/refresh" I do have the required scopes.
In my dev env I had a temp URL set to callback URL for the webhook when first creating the webhooks. And as I can't delete it I don't seem to be able to change the URL.
The other interesting thing is the documentation states: "This URL must use the same base URL as the Connect app" I'm guessing the intention is the same for Oauth 2 integrations however the placeholder URL I had originally does not match the base URL of the integration but it supposedly successfully created the webhooks.
Any ideas if this API endpoint should be accessible to Oauth 2 integrations(or if the docs are wrong) and if not anyway workarounds available to update/edit/change the callback URL for webhooks?
It was right in front of me and I missed it, apologies! /webhook is what I was looking for not /webhook/refresh, copy pasta.
