×I am looking at refining our current permission scheme.
Is it possible to have one permission scheme that allows a user to log a bug in project x but not in project y using groups or project roles?
Or do I have to create individual permission schemes for each project and assign the appropriate roles across the schemes?
Hi Sam - Welcome to the Atlassian Community!
You can use a shared single Permission Scheme and control access by what Project Role you put the user in.
If that Project roles gets the permission to create issues for example, does this mean they will be able to create issues in all projects?
Where in the project role do I assign it to the one specific Project?
Project Role assignments are unique to each project and only apply to that project. Your Permission Scheme can (should) grant permissions to various functions in the Scheme.
Then for the project that you want to grant access/permissions, go to Project Settings for the project (you must be a project administrator). Then click on the People option on the left side.
Then you can assign a project role to a user. The user in that project role will only have access to the permissions for that project.
Thank you!!!
So when i add the project role in the permission scheme but not the project itself they will be restricted?
Correct. The Permission Scheme uses the Project Role (e.g. Developers) to grant a permission (e.g. Browse Project). Then within Project ABC, Joe Smith is added to the Developers role. He can now see issues in Project ABC, but not in any other project that uses the same Permission Scheme.
If you want him to see issues in Project DEF, then you would add him to the Developers role in project DEF. Then he could see issues in projects ABC and DEF but no other projects.
