OptionID Validator Configuration Question
Katie Pickrell February 28, 2023
I have a scenario where I have a multi-select field called "Feature Flags Enabled" with selection options of "INT Enabled", "STG Enabled", "PROD Enabled". What I am looking to do is to prevent the status of changing to "QA" without the INT Enabled option being checked.
I feel like this is either a Validator or Condition on the transition. I found one that allows for the value to be looked at against an OptionID but could not figure out how to change the OptionID to something other than NULL.
Any ideas for how to accomplish this? I am unable to use any paid plugin apps to accomplish this so looking for something out of the box or free.
Kelly Arrey
March 1, 2023
Hi @Katie Pickrell
I think the "Value Field" Condition is what you're looking for. 2023-03-01_12h20_09.png
Hope this helps!
Kel
Katie Pickrell March 1, 2023
Hi Kel - Yes this is what I was working on. I actually think I was getting tripped up on the fact that the Value field didn't look like I could type anything in because it's not a text box but I see that I can!
Thank you for helping to point me in the right direction!
Like • Kelly Arrey likes this
Mia Paulin
April 20, 2023
@mention If the solution is being implemented in code, I would you a try/catch block;  I'm a java person, so it would be
    try{ /* code that is developed to run and
               might cause an error */
   catch(typeOfException e){
              /*code that executes when
               exception is caught*/
Basically what you would do is make it to where it wasn't null and had to have a value, and if someone inputs a null value, return an error message in the catch block portion  For list of execption/error instances that can be caught in a try/catch, consult the API of whatever language you are programming in. (note: in Java, you can create your own sing the "throwable" interface)
Katie Pickrell April 24, 2023
Thank you! Unfortunately I am not a code person and have no idea how to implement things like this in code. Hopefully this may help someone else out though!
yous co
February 28, 2023
sorry
