×I'm tryin g to create a filter and have it Order By just story ID but it seems to order BY StoryID and all the sub tasks for that story. Can I do this? Thanks.
Hi Iarias,
Can you share the filter you have built so far? And where it is not working as you intend it to?
Hi John - Here's my filter.
status = "To Do" OR status = "In Progress" OR status = Resolved ORDER BY issuetype ASC
It's ordering by story first but when there's sub-task under the story it order the sub-tasks before the story. Thanks,
It is going to order the issues alphabetically - so if the issuetype starts with a value that is after Sub-task (like Task), then it will put the sub-tasks first. You need to order by another field if you want a different result.
