Hello!
I'm trying to edit the "epic" field, in the Plan Board from Agile, by dragging the issue to the epic column but it shows me an error "You do not have permission to edit issue XY-123"
I've checked my permissions with the "permission helper" and I have Edit Permissions for that issue.
Could someone help me?
Regards, Mage
Hi Mage,
Yes. Please check if you also have permissions under "Administer projects" (an not just permission for the Issue itself).
Hi Mage,
Beisde having the edit issue permission, could you check which other permissions do you have for the Project where this issue is into?
* https://confluence.atlassian.com/display/JIRA/Managing+Project+Permissions<br< a="">>* https://confluence.atlassian.com/display/JIRA/Editing+an+Issue
