Pie Chart Gadget in Jira Dashboard - Excluding unwanted labels from my pie chart
Jon Norton
I have used the Pie Chart gadget to try and show the total number of changes made by a particular workstream, they use labels on the tickets to identify particular product lines and brands.
Am I able to exclude labels from one pie chart so I can have one pie chart that looks at total number of changes by product and have a separate pie chart that looks at total number of changes by brand.
i.e Change1 might have the labels 'Product A' and 'Brand B' and rather than showing both of these on the same pie chart i would like to display and two separate pie charts
2 accepted
Tom Harris - Old Street
January 13, 2021
Hi @Jon Norton ,
As @Tessa Tuteleers has said, I don't think this is possible with the built-in pie chart gadget. However, this is one of the exact use cases we had in mind when developing Custom Charts for Jira.
You can select labels as the statistic type and then hide the ones you don't want to show simply by clicking the "eye" button in the options panel:
You can also change the order, colors and much more. You can try the app right now for yourself on our interactive app playground: https://www.oldstreetsolutions.com/jira-reporting-playground
I hope that helps with your question.
Tom - Custom Charts Product Manager
Tessa Tuteleers
January 13, 2021
Hi @Jon Norton ,
Welcome to the community!
The Pie chart gadget does not support this.
furthermore, I would always advice to keep different types of data separate, so if you categorise on Product and Brand, store that data separately as well (especially if they are linked among themselves i.e. Brand > Product).
Maybe think about Insight or (Cascading) select lists?
- Tessa
Jon Norton
Hi @Tessa Tuteleers
Thanks for getting back to me!
I'll see if the team can put product/ brands in separate fields!
What is Insight / Cascading?
Tessa Tuteleers
January 13, 2021
Insight is an asset management tool for Jira Service Management (now from Atlassian), Cascading select fields are native to Jira, where you have a double select list, the second depending on the first (where you could let product depend on brand, or the other way around, should this hierarchy exist).
Both give a level of security (only users you decide can create new "labels") and give you a better structured, less loose set of data for you to report on.
Good luck!
