I am a newbie as a Scrum Master. I added pie chart widget as seen below but I just need the current sprint, not all. I have a look at other Jira discussion it's said that I can get through "JQL filter." Could somebody please help me on how exactly to do the JQL filter? Or maybe does anybody have another solution?
Thank you for your help :)
Krisna
Hi Krisna,
I am assuming that the current widget is filtering on the entire project. What you can do is construct a JQL filter save it and then reference that filter in your pie widget. To do this follow these steps:
Wow, thank you for your fast response Jack.
Awesome! I was thinking to add some more useful widget for this sprint for the team:)Thank you so much.
Krisna
Glad to help! Let me know if you run into further issues.
