Sign up Log in
Possibility to move group members from one group to another in cloud
Baris Sehitoglu
Hi
I'm grooming my cloud my Groups, I have multiple groups and I want to merge them and put it  in a group to another group.
How can I achieve this in Bulk, is this possible ?
Regards
Baris
Justus Mueller
Heya,
The following would be my take. Interested to hear what others suggest :)
You could try using the User provisioning REST API to bulk update (The User provisioning REST API REST API (atlassian.com)). I'd recommend trying this in a test instance first since you will be using PUT
  1. Use GET /scim/directory/{directoryId}/Groups to get a list of all groups where in the resources array from the response you can get a list of all ID's
  2. Use PUT /scim/directory/{directoryId}/Groups/{id} to bulk change the members Scim group using an array of all the user Id's you want in said group as part of the PUT request
Please do let me know if you would like any further clarification!
Justus
Nic Brough -Adaptavist-
April 26, 2022
That's pretty much the answer I would have given if you hadn't got there first!
There is no "move", it's "add it to the new group, remove it from the old", and there's nothing built into Jira to do this en-masse.  I too would recommend a look at the REST API
Like Justus Mueller likes this
