Possible to search inside a Jira attachment?
Colum McAndrew
August 11, 2021
I'm wondering if it is possible to find tickets with attachments containing a specific text string. It doesn't look possible, but wanted to get that confirmed. It seems you can only use JQL to find tickets with attachments.
3 accepted
5 votes
Daniel Turczanski - JQL Search Extensions
August 24, 2021 edited
Hi @Colum McAndrew ,
Standard JQL doesn't easily allow it but the results can be quickly found using our professional indexing service:
After you install the app you can simply search:
attachmentContent ~ "my text"
Make sure to check the documentation.
I hope this helps!
Danie
Scott R
April 6, 2023 edited
In 2023 pricing, for a 2000 user company that would cost USD$ 11,856 / yr to do an occasional text lookup - that is not going to get a paid stamp from an C-level manager !
Like • Mario Hernandez likes this
subham_p
May 20, 2024
Hi @Daniel Turczanski - JQL Search Extensions
It appears that the feature has been deprecated from the plugin. Despite installing the recommended plugin, I was unable to execute a JQL similar to the one specified above. I also attempted to search for any information related to attachment content on the plugin's documentation page, but to no avail.
Jack Brickey
JQL does not support searching contents of attachments. JQL is simply a query language for DB fields.
Colum McAndrew
August 13, 2021
Thanks for confirming Jack.
Daniel Ebers
August 15, 2021
Hi @Colum McAndrew
seeing the perfect answer from Jack I just wanted to add that there is a Suggestion with Atlassian that you could vote for, this could lead to an implementation of the mentioned feature in case many customers do want to have it.
Currently one can recognize '99' votes.
There is also the mention of an Apps - just adding this in case you want to review it. I must admit that I have not tested it and therefore only can excerpt what can be seen on the linked Suggestion.
Daniel
Colum McAndrew
August 16, 2021
Thanks @Daniel Ebers. I'm more than happy to round it up to three figures.
Colum McAndrew
August 24, 2021
Many thanks Daniel.
Troy Anderson
https://jira.atlassian.com/browse/JRACLOUD-1210 has been open since 2003.  Voting for it is pointless.
