Post Function option missing
Hector Galura July 10, 2024
There's a step in a documentation that I don't see when I click on Add post function:
Click on "Add post function", then please choose the "Update Issue Status" option and click on "Add"
I don't see the option of "Update Issue Status". Is there a plugin that allows this option to be available ?
Scott Schellhardt
July 10, 2024 edited
The status should update as part of the transition can you provide some additional context of what you are looking to do ?
For some reason, the issue is not transitioning from "In Progress" to "Done". I found this article that is similar to my issue: https://confluence.atlassian.com/jirakb/issue-s-status-is-not-updated-after-it-is-transitioned-1189806019.html
I can't complete step 5 in the resolution because of the missing Post Function "Update Issue Status".
Like • John Funk likes this
Scott Schellhardt
July 10, 2024
can you show a screenshot of that transition in this view ? Screenshot 2024-07-10 at 4.10.26 PM.png
