Post function - Update issue custom field - Update Approvers
duynb92 September 2, 2020
Hi folks,
I am trying to add multiple users to Approvers field via post-function in workflow, but could not figure out what value should I use. I have tried user name, user email, user id but no luck.
Thanks in advance.
Jason D_Cruz
September 8, 2020
Hi @duynb92 ,
You can use the user's AtlassianID. To see how to find the ID, please follow the instructions in the article below
https://community.atlassian.com/t5/Jira-questions/where-can-i-find-my-Account-ID/qaq-p/976527
Find the ID of the user and paste it into the Custom Field value of the post function and it should work.
Is there any particular reason that you'd like to use the post function instead of an automation rule? I would recommend that you use the Automation functionality to set the value of the Approvers field. If you know the user beforehand you can also update the default value of the field.
Here's a guide to show you automation basics.
https://www.atlassian.com/software/jira/guides/expand-jira/automation-use-cases
Jason
duynb92 September 8, 2020
Thanks Jason, I ended up using Automation rule. Just curious how to do it using Post function.
Duy
Like Jason D_Cruz likes this
Jason D_Cruz
September 8, 2020
Great to hear @duynb92 !
I'm a Product Manager on Jira Service Desk and I'd love to learn more about how you are using Approvals in your organisation and any feature requirements you may have. Do let me know if you'd like to discuss this and I'll reach out to you by email.
Ste Wright
Hi @duynb92
What kind of field is Approvers? And are these specific users - or if not, how are these users identified?
Ste
duynb92 September 6, 2020
Hi @Ste Wright ,
Approvers field is Jira service desk default field.
These users I want to add are all users which already exist in JIRA system.
Duy
