Power BI connector over Multi-Level Cascading Select
Sebastian Quiroga
November 18, 2021
Can we use Power Bi connector to get data entered using your addon for Multi-Level Cascading Select ?
Thank you
Yuliia Maidanova -Alpha Serve-
Hello @Sebastian Quiroga
You can import multi-select cascading fields data using our Power BI Connector for Jira. Please select your field under the Custom Fields section at the Jira Core tab. The field will be imported within the Issues table.
If you need any further assistance, please contact us at support@alpha-serve.com or submit a support request here: https://aserve.atlassian.net/servicedesk/customer/portal/16
