I am running the following groovy script in Power Groovy:
import com.atlassian.jira.user.ApplicationUsers
def userManager = ComponentAccessor.getUserManager()
// Get the current date
def currentDate = new Date()
// Calculate the date one year ago
def oneYearAgo = Calendar.instance
oneYearAgo.add(Calendar.YEAR, -1)
// Get all Jira users
def allUsers = userManager.getAllUsers().collect { ApplicationUsers.from(userManager.getUserByName(it.name)) }
// Iterate through each user
allUsers.each { user ->
def lastLogin = user?.lastLoginTime
// Check if the user hasn't logged in for over a year
if (lastLogin && lastLogin.before(oneYearAgo.time)) {
// Mark the user as inactive
userUtil.deactivateUser(user)
println "User ${user.name} marked as inactive."
I am coming up with the following error(s):
startup failed: Script1.groovy: 2: unable to resolve class com.atlassian.jira.user.ApplicationUser @ line 2, column 1. import com.atlassian.jira.user.ApplicationUser ^ Script1.groovy: 3: unable to resolve class com.atlassian.jira.user.ApplicationUsers @ line 3, column 1. import com.atlassian.jira.user.ApplicationUsers ^ 2 errors
I can find the class and verify the path to them, what am I doing wrong?
We run version 8.20.10 of Jira Server
Interface ApplicationUser:
https://docs.atlassian.com/software/jira/docs/api/8.20.10/com/atlassian/jira/user/ApplicationUser.html
Class ApplicationUsers:
https://docs.atlassian.com/software/jira/docs/api/8.20.10/com/atlassian/jira/user/ApplicationUsers.html
Power Groovy's implementation is very minimal and unsupported.
I don't think it supports imports outside of the immediate plugin context (which probably only includes the main groovy classes).
You might still be able to use power groovy to achieve what you are trying to do, but it will be more difficult.
For instance, I'm not sure where you found userUtil.deactivateUser()... but that's not a method that exists as far I'm aware.
Here is a script that you can use/adapt that will not need any imports.
int numOfDays = 300 // Number of days the user was not logged in
Date dateLimit = (new Date())- numOfDays
def userUtil = ComponentAccessor.userUtil
def crowdService = ComponentAccessor.crowdService
Class UserService = ComponentAccessor.pluginAccessor.classLoader.findClass('com.atlassian.jira.bc.user.UserService')
def userService = ComponentAccessor.getOSGiComponentInstanceOfType(UserService)
def userSearchService = ComponentAccessor.userSearchService
Class UserSearchParams =ComponentAccessor.pluginAccessor.classLoader.findClass('com.atlassian.jira.bc.user.search.UserSearchParams')
def userSearchParams = UserSearchParams.newInstance(true, true, false);
def userList = userSearchService.findUsers("", userSearchParams);
def updateUser
def updateUserValidationResult
long count = 0
def groupManager = ComponentAccessor.getGroupManager();
userList.findAll{it.isActive()}.each {
if(groupManager.isUserInGroup(it.getName(),"jira-administrators"))
return;
def userWithAttributes = crowdService.getUserWithAttributes(it.getName())
String lastLoginMillis = userWithAttributes.getValue('login.lastLoginMillis')
if (lastLoginMillis?.isNumber()) {
Date d = new Date(Long.parseLong(lastLoginMillis))
if (d.before(dateLimit)) {
updateUser = userService.newUserBuilder(it).active(false).build()
updateUserValidationResult = userService.validateUpdateUser(updateUser)
if (updateUserValidationResult.isValid()) {
userService.updateUser(updateUserValidationResult)
count++
"${count} users deactivated.\n"
