Sign up Log in
Priority fields
Loretta April 6, 2020
How do I enable the priority fields for issues on a next gen board?
Zoi Raskou
April 6, 2020
Hello! You will need to add the field in the screen.
Go to Project settings -> Issue types -> <The issue type you want the field to appear in>
You can find the Priority field in the Previously created fields (bottom right). Simply drag and drop it in the Context field.
Good luck !
Upcoming Jira Events
