When i post the worklog using rest api, the date posted and date logged is showing different for someone of different timezone.
format yyyy-mm-dd h:m:s.S+0000 utc timezone
I tried to set date in utc format but it shows the correct date for me but when my friend in different timezone posts a worklog there is discrepancy between the date posted and date logged in jira.
How to solve this? In what format and in what timezone i should set the date format that should be standard for any one in any time zone.
@Vaibhav Bansal , it depends on the timezone set on the user profile's settings.
Make sure that your account is in UTC.
Then the other users' will see the time converted from UTC to their preferenced timezone
My account is in Jira Default (GMT+00:00) UTC
Is there any other method or date format that can be used so that a standard timeline can be maintained using jira rest api
The standard time is determined by the profile setting timezone. Make sure that other users are also updating their timezone accordingly.
Time logged for an account that has GMT+5:30 cannot be viewed same value for the person who has GMT-1:30. JIRA will have the same standard value in the database and convert it in view to the user according to their profile preference. Hope that make it clear..
