×Hi there.
I can't figure out why some context fields aren't showing in my tasks.
Background and things I've checked
Fig. 1. Screen scheme (in project configuration)
Fig. 2. Screen fields (in admin screens fields configuration)
Fig. 3. Issue design. Context fields (in project configuration)
Fig. 4. Issue view. Context fileds in the right side of the screen
Fig. 5. Issue design. Description fields (in project configuration)
Fig. 5. Issue view. Description fileds in the left side of the screen
So I'm missing something but don't know what.
Could somebody please suggest something?
Thank you very much in advance.
M
Hi there.
I just opened one of the projects to continue dealing with the configuration problem and the hidden fields are now showing correctly.
I'm pretty sure it has something to do with the permissions scheme that I'm using. It's a custom one and I've been messing up with it more than what was convenient, so I don't know which was the faulty permission.
Anyway, thanks again.
M
Thanks a lot for your quick reply, @Dave Mathijs .
The fields are all placed in the Context section, so none are in the Hide when empty or Hidden sections.
If you're referring to a different configuration option, please let me know because I'm probably unaware of its existence :)
hi, did someone manage to fix this? I got the same problem.
I have the same issue, Company managed project, added progress fields to "context" and its not showing up anywhere.
I'm having exactly same issue, it is unfortunate that there is no answer provided here. For my it is happening with labels field
