Problem with creation Sub-task in project
Deleted user November 10, 2023
Good day, everyone.
Need help with problem about creation Sub-task. Sub-Task issue type already include in Issue type scheme. Project uses several worklows for different issue types.
The main problem that creating Sub-tasks allowed only from one issue type - change request -  but can't create from bug issue type although they use similar workflow. From other issue type no buttion create sub-task.
Can someone, please, help with it?
Thank you
Deleted user November 22, 2023
The problems solved.
In Scriptrunner -> Fragments -> Hide system or plugin UI element were chosen following parametrs:
com.atlassian.jira.plugin.system.issueoperations:create-subtask
com.atlassian.jira.plugin.system.issueoperations:issue-to-subtask
and chosed issue types for which it is true
Mayur Jadhav
Hi @[deleted] ,
Welcome to the Atlassian Community!!
Could you please share screenshot for the same and can you please check weather the Bug issue type is a standard issue type ?
Hi @Mayur Jadhav , ty, 3 sreens bottom.
On 3-rd screen issue types in scheme.
On 1-st screen main problem - ticket Bug and i can't create sub-task
On 2-nd screen - i've changed issue type on Change Request and button appears and i could create sub-tasks
Both this issues types use similar worklfow
Register here ⬇️
