I would like to configure the card issue on my project's board (software project).
1. Is there a way to add labels (field) to be presented on the card layout?
2. Is there a way to remove the three dots from the card layout? I don't want it to be presented at all:
Hi Dana,
Yes, label field can be added in card layout.
The red dots you mentioned, those are Days in column, represents how many days that particular issue is in that column (status). By default it is enabled in kanban & disabled in scrum board, but you can choose either way. There is a toggle for this feature on board setting, you can switch it on / off with that.
Barnali
We have Jira Cloud Standard, and I dont see this feature any more. I see the More, but I only see 'Customize Cards', which leads to a list of about 20 issue fields that can be toggled on or off. 'Days in column' is not one of them.
