I am looking for a tool with complete Jira integration which includes functionality such as :
Reasonably straight forward to implement and easy to use.
What can you suggest? TIA
Hi @The Guv --
Tempo Cloud app Cost Tracker for the financial management of your projects:
Cost Tracker is built to turn Tempo Timesheets time tracking data into a picture of your project's costs.
And new to the Tempo family is ALM Works Structure and Structure.Gantt for project management, which are very popular and powerful in their own right.
Hope this helps your research and the journey you are on!
Carolyn
Tempo Customer Success
Hi @The Guv ,
For me (and this is really a personal preference) I would suggest BigPicture (https://marketplace.atlassian.com/apps/1212259/bigpicture-project-management-ppm)
It's designed for Project and Portfolio management and has a module for resource and capacity management.
They also recently (from version 8 and up) added a module for Cost management.
In the past they would integrate with another app vendor (Tempo) for time and cost tracking but they start moving away from that and having everything in their own app.
Hi @The Guv
