Project UI issue and missing feature
GPY July 7, 2022 edited
A few months ago I created to "team managed" projects and set similar settings for both.
Today I wanted to mark an epic as "done" from my board on project 2 and I realized that the Epic dropdown menu is missing. The UI are actually different, the Epics and Version panel are on the top of the board instead of to be the side and I don't have Epic dropdown menu.
How can I fix this UI and get them behaving the same way?
How do I get back the dropdown on the Epics?
*Screen 1 is the good project with panel on the side and dropdown menu one epics, screen 2 is the issue.
Thuan_ Do Dang
July 8, 2022
Hi GPY,
If you just want to "Mark as Done" the Epic to hide it in the Epic panel, you have to Done all Issues in Epic first (the progress bar is full of green). Then you change Epic status to Done (expand the Epic > view all detail > update Epic status on the Issue detail view), it will disappear from your Epic panel.
GPY July 8, 2022
Thank you for your reply!
My Epic is 100% Done, and switched to Done (status is Done too, you can check the following picture). Yet it is  still visible.
Fixing this specific issue in one thing, but I want to understand why I got different UIs and how to fix it. I want to provide similar experience to my team members through all of our projects.
Register today
