Project and Task Tracking
bruce_white May 6, 2022
Is there a way to track a project and determine the amount of project completion as each task is completed?
So say I have a project and assign different users with different tasks. As those tasks are completed, is there a way to see a percentage of the overall project?
Jack Brickey
you could use a pie chart gadget to show issue by status or even status category. have you considered that?
jql - project = ABC
pie chart by status category: To Do, In Progress, Done
John Funk
Hi Bruce,
The best way to do that would be to create and Epic and link the tasks under the Epic. Then on the Epic, it would show you the percent done.
Register now
