Pros/ Cons Big Picture vs. Structure (Gantt)?
Milena Merten (DE) June 19, 2022
I'm Milena and I'm currently working for a client who is implementing a new version of Jira. We are currently in the phase of finding out which additional apps the customer needs. Specifically, we are now looking at a comparison of "Structure (Gantt)" vs. "Big Picture". Do any of you know the differences/advantages? Many thanks in advance!
Fabian Lim
Hi @Milena Merten (DE)
If you share your specific requirements I can give you an honest opinion on both apps.
Both apps are excellent, but depends on what the requirements are.
Regards
Milena Merten (DE) June 27, 2022
Hi @Fabian Lim
Thanks for your answer.
The main requirements are the following:
- Time values:
Set up an aggregated view in the portfolio as a portfolio manager needs consolidated time values at project level. Estimated hours for a project should be contrasted against actual hours
- Gantt Chart:
Creation/visualisation of a Gantt chart within a project. Critical path , milestones and dependencies (if one task moves, all the other dependent tasks move as well) should be shown.
- Portfoliomanagement:
Overview of all running projects incl. key facts (timeline, budget, resources, etc.)
If you need more details please tell me.
Milena
Fabian Lim
I would go with bigpicture based on the requirements since it looks more like a ppm solution that you need.
Times values:
  • Both are able to aggregate ay the project level for estimates and actuals.
Gantt chart:
  • both have dependency mapping and updates on dates when parent tasks moves.
  • Both can set milestones
  • Bigpicture has the critical path view, but I can remember seeing it in structure Gantt.
Portfolio:
  • The portfolio views and resource management in bigpicture would be the main difference.
  • Bigpicture let's you create groupings which are very useful for portfolio views.
  • It has the notion of teams and resource management which will help you capacity management.
That being said, I would recommend you try both tools before you make a final decision.
This is a video of what we built for a client: https://youtu.be/rSwyXDxgZvk
Using bipcture and a bunch of other plugins for an end to end ppm solution
Like • 8 people like this
Awesome! Thank you very much Fabian!
10 votes
Tam _DevSamurai_
Hi Milena,
Looking at your requirements, I believe that you should consider taking at look at TeamBoard ProScheduler as well. ProScheduler is resource planning scheduler and Gantt chart for Project and Portfolio.
Features
  • Resource planning: manage resources in Team, Project and Portfolio
  • Workload: Plan tasks monitor utilization
  • Table: no more Excel, manage Jira issues in a Spreadsheet view
  • Gantt chart and timeline
  • Time tracking
  • Reports
  • Project budget, cost (coming soon)
Please take a look at 5-min demo video for more details
https://www.youtube.com/watch?v=gLTWucsJUpw
Tam
Marta Pastor _Appfire_
October 21, 2022
My name is Marta, I am a Product Manager from BigPicture (Appfire). I am very glad to see that you considered implementing BigPicture for your client. I just wanted to drop this message to let you know that in case you have any questions regarding BigPicture I would be more than happy to connect and have a chat.
From the requirements you have shared, including Time values, Gantt chart and Portfolio management functionalities, it seems like BigPicture would indeed be a great solution for your client. I would be happy to walk you through those areas and hear your feedback.
@Fabian Lim thank you for recommending BigPicture, great to know it is being appreciated in the Atlassian Community.
Best,
Marta
FREE
